[Xi...] Posted November 18, 2021 Share Posted November 18, 2021 does anyone else offline seat has same problem? language setting is English. tool bar shows ok. but any feature select or utility menu change to Germany. 😮 😮 😮 Link to comment Share on other sites More sharing options...
[Cl...] Posted November 18, 2021 Share Posted November 18, 2021 I know if the program was created in German you can't change it by selecting a different language. You can translate what's there and change it. Not sure what's going on in your situation? Link to comment Share on other sites More sharing options...
[No...] Posted November 19, 2021 Share Posted November 19, 2021 Yes, already existing feature names do not change as they are only suggestions that can be edited freely by the user. Also they may be referenced by external systems (think of SPC software) which may react funny if an expected chracteristic name suddenly changes to something else. So language change only affects internal text strings like in menus and windows, but none of the names the user has created. If any menu items etc. are still in German after the change it's either because of a bug (very likely, haha 😉) or because the window hasn't been closed inbetween. To be sure, better close and restart Calypso after the change. Link to comment Share on other sites More sharing options...
[Ri...] Posted November 19, 2021 Share Posted November 19, 2021 Is it possible the initial install had the German language selected? If that is the case, uninstall and reinstall with the language you prefer. Link to comment Share on other sites More sharing options...
[Xi...] Posted November 19, 2021 Author Share Posted November 19, 2021 thanks to all reply. the problem is Default Name accidently ticked as Activate Name allocation.Default Name.jpg Link to comment Share on other sites More sharing options...
