Script in a Report page
I have a multi stage report and I want to generate a list of stages included in the report.
Previously we have inserted screen shots to show this list but this is manual, can easily be forgotten and is not elegant!
I want to insert a script to generate a list of active stages such as the below:
>import gom
>for i in range(len(gom.app.project.stages)):
>>  if (gom.app.project.stages[i].is_active):
>>      filetxt=(gom.app.project.stages[i].name)
>>     print(filetxt)
Any thoughts how i can achieve this?
You have to use Python. This is what I understand you have to do: create a txt file in a specific directory and print inside it the number of the stages. This is the simple code I have done for your usage:
import gom
stages=(len(gom.app.project.stages))
f = open("F:\Coacarqb\Marco\File.txt", "w")
f.write (str(stages))
f.close()
Is that useful for you?
Keith,
This will give you a list of the stage names, as they are set to active, and save it to a text file. I hope this helps.
import gom
active_stages = []
	gom.script.sys.show_stage (stage=gom.app.project.stages[i])
	gom.script.sys.set_stage_as_reference (stage=gom.app.project.stages[i])
	active_stages.append(gom.app.project.stage)
textfile = open("C:/Users/ZEISS/Documents/GOM/Results/stages.txt", "w")
for stage in active_stages:
	textfile.write(stage + "\n")
textfile.close()
Thank you both, however I cannot get either code to work "(unicode error) 'unicodeescape' codec cannot decode bytes in position 2-3: truncated \UXXXXXXXX escape "
I added "r" to the string to make them raw and then
's code counts the number of stages, and
's fails because a disabled stage cannot be made active.
I've modified the code as below:
to give me a list in the text file.
I'm looking for a Table of Contents style of finished page, so do you know of a way to get the information from the text file into the GOM Report (without manual copy/paste)?
Hello Keith,
One solution is to pass the text into a user defined Keyword. The Keyword can be placed as usual in a report page.
Hi Nanno,
When I create a new Keyword, I see an option for text, date, or number. I assume I would set it to text, but how would I direct it to the text file?
Edited
added a word for clarity
Hi Mark,
the text can be directly assigned to the keyword without a text file. Record the creation of a keyword and you can switch the string for a variable, which would be the name of a stage for example.
Regards,
Nanno
