Different between cartesian vs x/y call out?
Cartesian Distance: The length of a straight line perpendicular to the second feature to the center point of the first feature. Note, be sure to use the second feature as the reference.
X/Y: The X/Y coordinates of the feature origin on whichever alignment it is on. Open a feature, and look where the trihedron appears, that is your feature origin and the result of the X/Y coordinate. Not great since features will always have some angle deviation so you could get some odd results especially on cylinders.
X ,y values are the particular features local co-ordinate value.
Cartesian distance use centroid of the feature.
Reason is that the form error and projection angle deviations of the feature. So it is obvious you'll get different values.
  • 1 month later...
I'm still confused. After I origin and aligned the part, I would use x/y/z callouts for most callouts instead of cartesian? When would I need to use cartesian?
