[Th...] Posted September 27, 2021 Share Posted September 27, 2021 Sometimes I noticed the result will vary a bit if I pick cartesian distance vs standard x or y call out on say for example datum -B- wall to a hole. Why is that? Link to comment Share on other sites More sharing options...
[Pe...] Posted September 27, 2021 Share Posted September 27, 2021 Cartesian Distance: The length of a straight line perpendicular to the second feature to the center point of the first feature. Note, be sure to use the second feature as the reference. X/Y: The X/Y coordinates of the feature origin on whichever alignment it is on. Open a feature, and look where the trihedron appears, that is your feature origin and the result of the X/Y coordinate. Not great since features will always have some angle deviation so you could get some odd results especially on cylinders. Link to comment Share on other sites More sharing options...
[SH...] Posted September 27, 2021 Share Posted September 27, 2021 X ,y values are the particular features local co-ordinate value. Cartesian distance use centroid of the feature. Reason is that the form error and projection angle deviations of the feature. So it is obvious you'll get different values. Link to comment Share on other sites More sharing options...
[Th...] Posted November 12, 2021 Author Share Posted November 12, 2021 I'm still confused. After I origin and aligned the part, I would use x/y/z callouts for most callouts instead of cartesian? When would I need to use cartesian? Link to comment Share on other sites More sharing options...
[SH...] Posted November 13, 2021 Share Posted November 13, 2021 Please sign in to view this quote. It will be useful, when you want to check distance that are non parallel to the alignment axis. Link to comment Share on other sites More sharing options...
