Excel file header change and save
Hello there
Without PCM, I can add the report_end_pcm file into the program and copy the excel files to a different address and change the file name as I want.
I am saving pdf files in the following format. Can I name and save excel files in the same way.
D:\MEASUREMENTS\+getRecordHead("date")+"__"+getRecordHead("drawingno")+"__"+getRecordHead("u_field11")+"__"+getRecordHead("u_field8")+"__"+ getRecordHead("u_field9")+"__"+getRecordHead("partnbinc")+".pdf"
Thanks
