[Aa...] Posted November 9, 2021 Share Posted November 9, 2021 Okay, I'm trying to set up a program so that all the points in the .zmp file are in the coordinate system of the machine. If I create a copy of each feature with a " - machineCoord" tag on the end of the name, and change it's coordinate system to an alignment "Machine", based on the CMM Alignment, and with no features included or transformations, and then "Recall Feature Points" from the original feature in the Base Alignment without adjusting the nominal geometry, what would that do? Link to comment https://qualityforum.zeiss.com/topic/11646-hypothetical-experiment-recall-feature-points/ Share on other sites More sharing options...
[Me...] Posted November 9, 2021 Share Posted November 9, 2021 Please sign in to view this quote. Generate a duplicate file in the "geoactuals" folder with a different name..... Are you just needing a file for each feature where the measured points are represented in machine coordinates? Link to comment https://qualityforum.zeiss.com/topic/11646-hypothetical-experiment-recall-feature-points/#findComment-57730 Share on other sites More sharing options...
[Aa...] Posted November 10, 2021 Author Share Posted November 10, 2021 Please sign in to view this quote. Yes, that's what I'm trying to accomplish with this. Does anyone know what the numbers in the "scbada" lines of the geoactuals files represent? Link to comment https://qualityforum.zeiss.com/topic/11646-hypothetical-experiment-recall-feature-points/#findComment-57732 Share on other sites More sharing options...
[Me...] Posted November 10, 2021 Share Posted November 10, 2021 Best I can tell is that those lines are used for assigning points to the appropriate path within the strategy. Discrete points will have a line for each measured point and scanning paths will have one line for each. I would say that the best option for you is to use the writeActualsToFile() function in order to have the measured points exported in machine coordinates. You can do this without having the PCM option using a result element or text element. If you don't have PCM and would like to have an external PCM file execute the code, send me a PM and I'll tell you how to do it.. Link to comment https://qualityforum.zeiss.com/topic/11646-hypothetical-experiment-recall-feature-points/#findComment-57734 Share on other sites More sharing options...
