[Da...] Posted November 9, 2021 Share Posted November 9, 2021 Morning all, I have a few programs where, when I evaluate the measuring points it will only generate 30% of the characteristics, the rest are greyed out like they have never been checked. I can not work out the solution. Furthermore, I really need this to be working OK, as we do a lot of simulation and investigation based on previous data. We use Calypso 5.4 and programs are on a network drive. Any suggestions please ? Link to comment Share on other sites More sharing options...
[Sh...] Posted November 9, 2021 Share Posted November 9, 2021 Is it possible those runs are Mini-Plan runs? Link to comment Share on other sites More sharing options...
[Ja...] Posted November 9, 2021 Share Posted November 9, 2021 If you make a change to the program like adding more points to a feature strategy, the feature will not calculate with the saved points. Link to comment Share on other sites More sharing options...
[Ke...] Posted November 9, 2021 Share Posted November 9, 2021 Please sign in to view this quote. I knew that if the name of the feature changed, then the points would not load; but I was not aware that changes in the strategy could cause problems. Good to know! Link to comment Share on other sites More sharing options...
[Da...] Posted November 9, 2021 Author Share Posted November 9, 2021 No changes at all I knew that the changes will make a difference but I ran the program yesterday and the measurements points working only partially today so I do not understand unless is something to do with PCM but why the other programs are ok ? Link to comment Share on other sites More sharing options...
[Ja...] Posted November 9, 2021 Share Posted November 9, 2021 Please sign in to view this quote. I think I may be wrong about that. It does seem to still work but obviously only has the original strategy points. I remember having the same issue. Maybe it was the name change. Link to comment Share on other sites More sharing options...
[Da...] Posted November 9, 2021 Author Share Posted November 9, 2021 Ok so let's say that someone has changed the program in the meantime. What is the solution to fix this program for future pursposes ? Untick the measurement points, saved, re-open and ticked again or will it be fu*cked forever ? π€£ Link to comment Share on other sites More sharing options...
[Ke...] Posted November 9, 2021 Share Posted November 9, 2021 Please sign in to view this quote. If you can re-name them what they were originally, the points will re-load Link to comment Share on other sites More sharing options...
[Aa...] Posted November 9, 2021 Share Posted November 9, 2021 If you want to see what feature names you have measured points for in each data set, you can. Within the "idmeaspoints" folder of the plan, there is a .zmp file for each run. If you change the extension to .zip, you can open it as a normal .zip file. The contents will be an extensionless file for each feature for which points were collected in that run. (Basically, they're tab-delimited .csv's of the ball-center points and the calibration data for the styli used in a kind of funky layout.) The size of each file will depend on how many points were collected. Oh, and don't forget to change the extension back to .zmp before trying again to load the points in Calypso. π Oh, and all of this is assuming that the points were saved by setting Measuring Points to "On" in Resources>Results to File... Link to comment Share on other sites More sharing options...
[Da...] Posted November 9, 2021 Author Share Posted November 9, 2021 Thank you guys for all this answers, but how stupid it was to design like that? π I will try to save as a new program without them and switch back on in the new program. I will let you know if it worked. Link to comment Share on other sites More sharing options...
[Da...] Posted November 10, 2021 Author Share Posted November 10, 2021 Morning. I found the problem. I use ΓΈ in my features name and inside .zmp files instead of ΓΈ somehow they have been changed to O. Once I change them in my program to O I can see the data. This is ridiculous anyway. I am wondering if it's like that because of old Calypso 5.4 Do you have the same issue with the latest software too ? Link to comment Share on other sites More sharing options...
[Aa...] Posted November 10, 2021 Share Posted November 10, 2021 Yeah, the good 'ol diameter symbol. I used to do that, until I realized how much they screwed things up. I would do exactly what you said about replacing them with O in the program. And I would recommend you ditch the practice of using the symbol in feature names, altogether. Link to comment Share on other sites More sharing options...
