[Ti...] Posted July 16, 2022 Share Posted July 16, 2022 I'm feeling good about the software, but then I run up to something like this that is so simple on a CAD system, but I cannot figure it out. I've created a circle and a point and I would like the distance in Z b/w the two. I can only get the distance from point to point right now. Also, is there a way to just click the point and find out it's coordinates from the current coordinate system? I tried to do that so I could just write the Z height down and subtract them to get the value, but I couldn't find where to get the position of the feature/points. Thanks! Link to comment Share on other sites More sharing options...
[Ti...] Posted July 16, 2022 Author Share Posted July 16, 2022 I found the solution....I get messed up b/c you have to create a dimension first and then you do your Z height as a 'check'. Inside the check feature you can isolate the Z height to find this dimension. Link to comment Share on other sites More sharing options...
