[No...] Posted November 2, 2021 Share Posted November 2, 2021 Am I getting old or what? 😮 Calypso 2018 (6.6.28), offline seat. I have an existing program, containing a plane with space axis -X and a scanning strategy (circles) I copy the plane, change its X coordinate from 0 to -20 and run it in simulation. When I open the plane afterwards, the strategy lines have snapped back at where the plane originally was, and also the actual points are displayed at the old location. This is just one of those Tuesdays, right? Strategies should move with the feature, right? 😕 Never seen this before. Original: Copied: After run: Link to comment Share on other sites More sharing options...
[No...] Posted November 2, 2021 Author Share Posted November 2, 2021 AAAAAH, I AM getting old !! 🤣 🤣 No, I won't tell - see if you can guess it 😃 Link to comment Share on other sites More sharing options...
[To...] Posted November 2, 2021 Share Posted November 2, 2021 Please sign in to view this quote. 😮 Link to comment Share on other sites More sharing options...
[No...] Posted November 2, 2021 Author Share Posted November 2, 2021 Shhhhhh! 🫣 Link to comment Share on other sites More sharing options...
[Cl...] Posted November 2, 2021 Share Posted November 2, 2021 Two things happen when you get old. The first thing is, you lose your memory. I can't remember what the second thing is. Link to comment Share on other sites More sharing options...
[No...] Posted November 3, 2021 Author Share Posted November 3, 2021 Please sign in to view this quote. 🤣 🤣 🤣 🤣 🤣 🤣 Link to comment Share on other sites More sharing options...
[An...] Posted November 3, 2021 Share Posted November 3, 2021 do not come up with it myself! Possibly today is one of those Wednesdays 🤣 🤣 🤣 Link to comment Share on other sites More sharing options...
[Ma...] Posted November 3, 2021 Share Posted November 3, 2021 😮 Link to comment Share on other sites More sharing options...
[Ke...] Posted November 3, 2021 Share Posted November 3, 2021 Circle pattern, with formula? Link to comment Share on other sites More sharing options...
[No...] Posted November 3, 2021 Author Share Posted November 3, 2021 Circle yes. Pattern no. Formula yes. But not the cause. 🤠Embarrassingly simple. Tom nailed it, but deleted it. 😃 Link to comment Share on other sites More sharing options...
[An...] Posted November 3, 2021 Share Posted November 3, 2021 Plane with offset ? Link to comment Share on other sites More sharing options...
[No...] Posted November 3, 2021 Author Share Posted November 3, 2021 Much simpler. The first post has all the info needed. 😉 P.S.: In the second image, the CAD view is deceiving... Link to comment Share on other sites More sharing options...
[An...] Posted November 3, 2021 Share Posted November 3, 2021 what price do you get for the solution? Link to comment Share on other sites More sharing options...
[Da...] Posted November 3, 2021 Share Posted November 3, 2021 Please sign in to view this quote. As always, top quality binoculars. -> viewtopic.php?p=33977#p33977 Link to comment Share on other sites More sharing options...
[No...] Posted November 3, 2021 Author Share Posted November 3, 2021 Please sign in to view this quote. Increased Knowledge™ 🤣 Link to comment Share on other sites More sharing options...
[Da...] Posted November 3, 2021 Share Posted November 3, 2021 You forgot to delete the old plane? Link to comment Share on other sites More sharing options...
[Ma...] Posted November 3, 2021 Share Posted November 3, 2021 Are you sure that formula to get X,Y,Z are not in charge? Link to comment Share on other sites More sharing options...
[No...] Posted November 4, 2021 Author Share Posted November 4, 2021 Please sign in to view this quote. Yes 🤠Let's not take this too far, since it's really a simple problem. But after so many years you may have become accustomed to ignoring information you think you don't need. At least now I know I'm not alone 😃 So here's the solution: Link to comment Share on other sites More sharing options...
[Ma...] Posted November 4, 2021 Share Posted November 4, 2021 One thing i noticed - coordinates doesn't correspond to feature point. Link to comment Share on other sites More sharing options...
[Ke...] Posted November 4, 2021 Share Posted November 4, 2021 The startegy X value does not "move with the plane", unless you use a forumula to connect the paths to the features nominal value. Link to comment Share on other sites More sharing options...
[No...] Posted November 5, 2021 Author Share Posted November 5, 2021 Please sign in to view this quote. I guess I never even thought about doing that (referencing a formula to the same feature) because I'm subliminally afraid of building a circlular reference.somewhere. Link to comment Share on other sites More sharing options...
[To...] Posted November 5, 2021 Share Posted November 5, 2021 It does seem odd that it doesn't move with the feature. A polylines, grids, points all do. Link to comment Share on other sites More sharing options...
[No...] Posted November 8, 2021 Author Share Posted November 8, 2021 Please sign in to view this quote. Programming sloppyness if you ask me. Thinking about it, it's not even logical to always use (base) alignment coordinates for the center of the circle. I measure rectangular planes almost all the time, so I never had to think about this, but what does it do when the plane is under an angle to the alignment? Other feature types either reference the feature coordinate system or let you choose which method to use. Link to comment Share on other sites More sharing options...
[He...] Posted November 8, 2021 Share Posted November 8, 2021 Normally circle path on plane moves with the plane but if you have any formula for the location it will not move at all. In this case it seems you have formula for Y and Z and that causes X not to move with the plane. Bug or feature? Is there any way to tell anymore? Link to comment Share on other sites More sharing options...
[No...] Posted November 9, 2021 Author Share Posted November 9, 2021 Please sign in to view this quote. Sounds reasonable, that's probably why I never encountered this before. I work a lot with formulas in the circle location, but I never tried to copy such a plane before. It would have been nice of Calypso to ask me if I want to move the strategy as well 🤣 Link to comment Share on other sites More sharing options...
