[Ke...] Posted November 3, 2021 Share Posted November 3, 2021 Profile of Datum A (plane), with no applied Datum. I have it set up with: Feature: Datum A with LSQ Datum(s): Datum A with Minimum Feature ...which is equal to Flatness. Without Freeform as an option: Is this method correct? Link to comment Share on other sites More sharing options...
[Ma...] Posted November 3, 2021 Share Posted November 3, 2021 You can use Surface Profile for plane even without FFS. Link to comment Share on other sites More sharing options...
[Ke...] Posted November 3, 2021 Author Share Posted November 3, 2021 Please sign in to view this quote. Yes sir. I'm using Surface Profile, but; without FF you need to apply Datum Feature(s) Link to comment Share on other sites More sharing options...
[Ma...] Posted November 3, 2021 Share Posted November 3, 2021 Well then apply plane itself 3 times Link to comment Share on other sites More sharing options...
[Cl...] Posted November 3, 2021 Share Posted November 3, 2021 Link to comment Share on other sites More sharing options...
[Ke...] Posted November 3, 2021 Author Share Posted November 3, 2021 Please sign in to view this quote. So, there are two ways to go about it to get the same answer: Load the Datums & go with the default Outer Tangential *but* select "Bi-Lateral - two results" OR (As I did) Load the Datums & change the Evaluation Methods to "Minimum Feature" and leave the reporting as "Bilateral - one result" Both results give the same value(s) as Flatness/Form. I was second guessing myself, but it's good to know both methods. Thanks Gents! Link to comment Share on other sites More sharing options...
[Ma...] Posted November 3, 2021 Share Posted November 3, 2021 I don't know how it is at you, but Profile is usually evaluated as one result - basically doubled worse deviation. If you used eval for plane as LSQ, then profile should get doubled flatness. ASME i presume - for ISO is for all Gauss Link to comment Share on other sites More sharing options...
[To...] Posted November 4, 2021 Share Posted November 4, 2021 Please sign in to view this quote. The problem with using one result is that you don't know if your deviation is plus or minus or both without looking at a plot. By using two results, you can determine where the deviation is. It splits the tolerance in half but still show green or red, same at one result. Link to comment Share on other sites More sharing options...
[Ma...] Posted November 4, 2021 Share Posted November 4, 2021 Please sign in to view this quote. I know this and you can use it for your needs, but on report for customer must be what i said. Or it should be mentioned on drawings. Link to comment Share on other sites More sharing options...
[Ro...] Posted November 4, 2021 Share Posted November 4, 2021 Please sign in to view this quote. That may be true for ISO but not for ASME. Link to comment Share on other sites More sharing options...
[Ma...] Posted November 4, 2021 Share Posted November 4, 2021 Please sign in to view this quote. Well i have to apologize. I found some discussions about ASME and ISO and it looks like in ASME is reporting MIN MAX values ( but also some were to stick to ISO MAX*2 ). And found one mention about reporting profile without datums for ISO - MIN MAX too. I'll try to look deeper for this. Every day is a learning day 😉 Link to comment Share on other sites More sharing options...
[To...] Posted November 5, 2021 Share Posted November 5, 2021 Please sign in to view this quote. I've looked for anything regarding profile per ASME but have never found any mention on how to report it. As far as I can tell, ASME 14.5 only shows how to interpret the tolerance zone. Anytime I've had a discussion with someone that said profile was the difference between min and max, they were a pc-dmis user. Can you post any specifics? Link to comment Share on other sites More sharing options...
[Ro...] Posted November 5, 2021 Share Posted November 5, 2021 Hi Tom, 14.5.1M, 6.5 has the information that I'm talking about. Check out the Actual Value portion of profile calculation. Here's a snippet.. I've never understood doubling the max result, like ISO does. It gives you no meaningful information, IMO. Plus, you can get errant/strange results with unequal distribution profiles. If you have a profile of 10 U.002 and your result is -.002,+.003, your part is out of tolerance, yet 2x .003 is .006, which is in tolerance? It's just a bizarre way to report profile, IMO. There's a lot of good stuff in Y14.5.1M. Most people just refer to 14.5 but there's a lot of really useful stuff in Y14.5.1M, IMO. Link to comment Share on other sites More sharing options...
