Position of Slot....Again
Hello everyone. Looking for suggestions on best method to report position on the slot below. This one is throwing me off a bit due to basic slot length
Datum Feature A is plane on bottom
Datum Feature B is plane on right end
Datum Feature C is plane, perpendicular to view.
TIA
I would treat it the same as a slot with rectangular coordinates and report each axis separately to the same tolerances in the FCF. Normally there will be a separate callout for each axis, but since there isn't, it's a linear tolerance zone, and it's position and not profile, I don't think you have another choice.
I guess you could report just the one direction that's shown and let the drawing notes/tolerances control the slot length and position. You'd either need a note with some sort of catch-all, like profile .xxx to A-B-C or something similar, or something like a general tolerance document that controls undimensioned features with a table of sizes and corresponding tolerances, similar to a hole chart.
The slot length, even though it has a basic, has no tolerance directly applied to it, so it's kind of a judgement call on whether to use the FCF or some other controlling method.
True position controls controls only the location of the slot center.
Slot width has a dimensional tolerance.
Slot length is basic and is not controlled in snippet shown.
I agree but then that brings up the question, "what is the tolerance on the length of the slot?"
There are a few "questionable" gd&t concepts on this drawing.... including a note regarding ANSI Y14.5, which leads me to think this might be a drawing from the early days....
[/quote]
That is odd. Normally there is a note or an all over profile to control basics.
Would the .390 Basic default to the UOS Block tolerance?
[/quote]
[/quote]
[/quote]
[/quote]
That is my understanding.
Negative. A basic dimension has no tolerance and is a theoretical perfect nominal. Features defined by basic dimensions derive their tolerances from the FCF.
Symmetry planes, symmetry points, or the old circle construction method to get the MMC. Maybe at a couple of depths, depending on the depth of the slot.
