[po...] Posted October 26, 2021 Share Posted October 26, 2021 I am trying to load an IGES model and i getting the following warning: IGS file cannot be loaded. The file does match a valid CAD format. The file opens fine in solid works. any help on this? Link to comment https://qualityforum.zeiss.com/topic/11698-loading-an-iges-model/ Share on other sites More sharing options...
[Da...] Posted October 26, 2021 Share Posted October 26, 2021 Try saving it as an ACIS file in solidworks, then it should load. Link to comment https://qualityforum.zeiss.com/topic/11698-loading-an-iges-model/#findComment-58138 Share on other sites More sharing options...
[De...] Posted November 4, 2021 Share Posted November 4, 2021 You can open IGS documents with diverse computing device CAD programs, together with Autodesk Fusion 360 (Windows), Dassault Systemes CATIA (multiplatform), Nemetschek VectorWorks (multiplatform), and CADEX CAD Exchanger (macOS). Link to comment https://qualityforum.zeiss.com/topic/11698-loading-an-iges-model/#findComment-58140 Share on other sites More sharing options...
