[Da...] Posted October 14, 2020 Share Posted October 14, 2020 So I have to activate a plate? Link to comment https://qualityforum.zeiss.com/topic/11704-device-activator-wt/ Share on other sites More sharing options...
[d8...] Posted October 14, 2020 Share Posted October 14, 2020 It's a means of ZEISS updating the OSIS directory of the controller. Think of it as updating drivers. It's really not a big deal. Link to comment https://qualityforum.zeiss.com/topic/11704-device-activator-wt/#findComment-58156 Share on other sites More sharing options...
[Da...] Posted October 15, 2020 Author Share Posted October 15, 2020 So, Its not a way for Zeiss to disable third party hardware ? Link to comment https://qualityforum.zeiss.com/topic/11704-device-activator-wt/#findComment-58158 Share on other sites More sharing options...
[El...] Posted April 26, 2021 Share Posted April 26, 2021 Yes that's right you need to activate the product. Link to comment https://qualityforum.zeiss.com/topic/11704-device-activator-wt/#findComment-58160 Share on other sites More sharing options...
[Ri...] Posted April 27, 2021 Share Posted April 27, 2021 Please sign in to view this quote. Correct. They made a change to the contacts on the XXT plates (they are gold now). It should only be a one time thing as well. Link to comment https://qualityforum.zeiss.com/topic/11704-device-activator-wt/#findComment-58162 Share on other sites More sharing options...
[To...] Posted April 28, 2021 Share Posted April 28, 2021 So what do you do if you don't have internet access? If you buy a new machine, should you assume this has already been done? Does each and every plate need to be done? Is there documentation that I can refer to? Link to comment https://qualityforum.zeiss.com/topic/11704-device-activator-wt/#findComment-58164 Share on other sites More sharing options...
[To...] Posted April 28, 2021 Share Posted April 28, 2021 Please sign in to view this quote. I seem to recall seeing this requirement prior to the introduction of gold balls. We got a new Accura II back around 2016 (ver 6.2) and saw the red card in the XXT box. Link to comment https://qualityforum.zeiss.com/topic/11704-device-activator-wt/#findComment-58166 Share on other sites More sharing options...
[Da...] Posted April 28, 2021 Author Share Posted April 28, 2021 I ran it once on one of three machines, one time...everything still works. Link to comment https://qualityforum.zeiss.com/topic/11704-device-activator-wt/#findComment-58168 Share on other sites More sharing options...
[An...] Posted November 3, 2021 Share Posted November 3, 2021 the Divice Activator is only valid for 42 days, after that you have to download the latest version from the portal. The current validity is always visible in the form of a bar in the Divice Activator. Link to comment https://qualityforum.zeiss.com/topic/11704-device-activator-wt/#findComment-58170 Share on other sites More sharing options...
[Me...] Posted November 3, 2021 Share Posted November 3, 2021 If you're not using the "ID Chip Recognition" functionality, then put some tape over the contacts.... Never worry about it again 😃 Link to comment https://qualityforum.zeiss.com/topic/11704-device-activator-wt/#findComment-58172 Share on other sites More sharing options...
