Evaluation method question
Copied from the help file:
"With the calculation as least absolute value feature (L1 feature), the geometric element is determined in such a way to minimize the sum of the deviation values. This best fit is insensitive against outliers and leads to a clear result with low computational effort."
I can't pretend to understand math anymore, but https://demonstrations.wolfram.com/ComparingLeastSquaresFitAndLeastAbsoluteDeviationsFit/ with a couple of graphs that show LAV basically ignoring outlier data.
I have found the L1 evaluation method has given me a good correlation with MarSurf or Talysurf evaluations, when scanning radii with segments less than 90 degrees (tested on samles with 50-70 degrees).
