Number of Records for PiWeb Reporting Plus
Quick question on the number of records able to be collected in PiWeb Reporting Plus. It is my understanding that 1000 records is the max for Plus, however the default setting is 200 records and that appears to be what it does. Has anyone successfully used 1,000 in this setting?
Why isn't the default set to 1,000?
I've set mine to 1,000. Haven't hit that cap yet, but I've got a database up to 397 measured items. No idea why it's set so low by default. I would guess it's some kind of attempt to limit database file sizes. Enough different parts with enough measurement characteristics and those databases probably get quite large.
Hello
With PiWeb Reporting Plus, you can record up to 1000 measurements. For more recordings, you need to switch to SBS. If you make the default 1000, it will record successfully. I can fill 1000 measurements in about 15 days. However, due to the slowdown in the automotive industry, this period will now take a long time 🙁
