[Cl...] Posted October 28, 2021 Share Posted October 28, 2021 I have a family of 11 parts. The geometry is exactly the same. The only difference is the OD threaded major Ø tip goes from 3.0mm thru 10.35mm. Using PCM, How do I get the curve to follow the size change? It's a cylindrical spiral curve extracted from the threaded tip. Link to comment https://qualityforum.zeiss.com/topic/11740-3d-curve-growing/ Share on other sites More sharing options...
[Mi...] Posted October 29, 2021 Share Posted October 29, 2021 You could use the point generator in the curve. Start Index: 0 End Index: 360*A A = number of coil, 360° Step: 1,0 Step width 1,0 point: point(cos(index)*R,sin(index)*R,(S/360)*(index),-cos(index),-sin(index),0) R = Radius, S = pitch Give it a try, i´ve never used it since 8 years ago. Goog luck 🙂 Link to comment https://qualityforum.zeiss.com/topic/11740-3d-curve-growing/#findComment-58370 Share on other sites More sharing options...
[Is...] Posted October 29, 2021 Share Posted October 29, 2021 There are some performance issues with the point generator, generate text files gives faster execution and also more parametrization options: viewtopic.php?p=22560#p22560 viewtopic.php?p=13419#p13419 viewtopic.php?p=21408#p21408 viewtopic.php?p=12892#p12892 Link to comment https://qualityforum.zeiss.com/topic/11740-3d-curve-growing/#findComment-58372 Share on other sites More sharing options...
[Is...] Posted October 29, 2021 Share Posted October 29, 2021 This has more potential for 3d: viewtopic.php?p=29138#p29138 Link to comment https://qualityforum.zeiss.com/topic/11740-3d-curve-growing/#findComment-58374 Share on other sites More sharing options...
[Cl...] Posted October 29, 2021 Author Share Posted October 29, 2021 Thanks to everyone for the input. I just found out that the feature (threads) extract as a cylinder. So I can just create a para file of diameters for each size. Link to comment https://qualityforum.zeiss.com/topic/11740-3d-curve-growing/#findComment-58376 Share on other sites More sharing options...
