Equally dividing the points
I don't know if this can be done without Curve. Unless there was some way to create the points from the cad model in cad software, give the X,Y,Z coordinates and then you program the points using the coordinates. Also, if you were to send your program to someone with curve, they could create the 25 nominal points, Extract the X,Y,Z coordinates for you to program if your company would allow this. Maybe someone else knows something I don't.
I think you might be able using CAD-Creating features. Section the model where you want and then go to point set, change to space points and From Curves. Grid length will be the number of points.
