[Da...] Posted October 21, 2021 Share Posted October 21, 2021 Hello. Is there any way to have two reports generated at the end of program ? I mean, one will be full normal and the 2nd one only with those characteristics that I need for concession. I know to have 2nd report with errors only, but I would like to select which characteristics I need. Link to comment Share on other sites More sharing options...
[To...] Posted October 21, 2021 Share Posted October 21, 2021 I did a video on this. https://youtu.be/s143So0ONqQ Link to comment Share on other sites More sharing options...
[Da...] Posted October 22, 2021 Author Share Posted October 22, 2021 Thanks a lot. I do not have a PiWeb but I will try Link to comment Share on other sites More sharing options...
[Da...] Posted October 22, 2021 Author Share Posted October 22, 2021 Unfortunately it is only working 50% I did manage to put two reports and mask out (hide) other characteristics, but it tries to overwrite my first report as the path and the name is the same. Unfortunately when I try to change the name or path or whatever to the 2nd report it also changes the first one. Any idea ? Link to comment Share on other sites More sharing options...
[Mo...] Posted October 22, 2021 Share Posted October 22, 2021 You can save the second report as a miniplan. Just select the characteristics you want in your miniplan, give it a name. Run your full program, get your full report. Start program again, select your miniplan and uncheck "Clear existing result" box. This will give you your shorter report only with the selected features in your miniplan and will also save it separately. Link to comment Share on other sites More sharing options...
[Da...] Posted October 22, 2021 Author Share Posted October 22, 2021 This is what we do now but sometime people forget that is why I need two reports to be done at the same time but thank you for suggestion. Link to comment Share on other sites More sharing options...
