(B-B) as secondary datum in DRF
I don't ever work with Iso drawings, so this is probably from lack of experience, but I'm very confused on a drawing I have. B datum is a pattern of holes consisting of 20 holes. I understand that B-B would indicate that it is more than one feature that makes up the datum. However, I have different callouts with a DRF of |A|B| and also |A|(B-B)|. I'm leaning towards it being a drawing error, because I don't understand how you can use both. I unfortunately don't have access to ISO GPS, but with some screen shots I've seen, it only indicates that (B-B) indicates multiple features.
My "best guess" is that the callout to IAIBI uses only the first B datum feature, while IAIB-BI is a seperate callout to indicate the use of a pattern... I suggest posting a screenshot or rough sketch of the callout; I'm sure that someone more familiar with ISO will comment, when they wake up 🤣
#heresyourbump
