[Ji...] Posted October 21, 2021 Share Posted October 21, 2021 Dear, If lineform without datum, can i use this function to evaluate?1.PNG2.PNG Link to comment Share on other sites More sharing options...
[Ma...] Posted October 21, 2021 Share Posted October 21, 2021 You can not use "form" characteristic because of result - "Form" will give you number which you must multiply by 2. I am sure you have defined radius as basic dimension. If drawing doesn't contain any of basic dimensions for this, then you can use "alignment from curves" to bestfit it and then report profile. If you don't have curves and FFS then tell it to us. Link to comment Share on other sites More sharing options...
[To...] Posted October 21, 2021 Share Posted October 21, 2021 Form result is the difference between Max and Min Deviation. To see an example of this, open a feature and look at the bottom You see a max point and a min point. The form result is the difference. Note: this is based on an LSQ evaluation. Using Minimum Feature evaluation would be similar to a roundness or flatness. Profile is the max deviation (note: this could be a negative value) times 2. Curves is the only option to report Line Profile, in my opinion. Link to comment Share on other sites More sharing options...
