Profile Question
you can try making individual features such as cylinder, planes. Use basic dimension to define their nominal values.
Evaluate profile for each individual features. If you want one result only, then use maximum result feature and pull all the individual profile characteristics to get one result.
This will be difficult to do depending on the depth of the cutouts. I believe if you created that planes and cylinders with all the correct size, length, geometry, etc. you can then take space points on these surfaces after they are created just as if you had a solid model. Then you can set these to a specific height, and report the greatest deviation doubled as your profile using the min/max results and a result formula. Maybe this will work for you.
