[Ad...] Posted October 15, 2021 Share Posted October 15, 2021 Hey guys, How would you go about checking the profiles? I do not have curve, and what is the best method to get the proper measurement? Thanks.Page 2.pngPage 1.png Link to comment Share on other sites More sharing options...
[Cl...] Posted October 15, 2021 Share Posted October 15, 2021 Without curve/Freeform, one option would be (lots) of space-points. Link to comment Share on other sites More sharing options...
[Ad...] Posted October 15, 2021 Author Share Posted October 15, 2021 Okay, but we do not have a CAD model, and how do I create space points? Link to comment Share on other sites More sharing options...
[Ja...] Posted October 15, 2021 Share Posted October 15, 2021 you can try making individual features such as cylinder, planes. Use basic dimension to define their nominal values. Evaluate profile for each individual features. If you want one result only, then use maximum result feature and pull all the individual profile characteristics to get one result. Link to comment Share on other sites More sharing options...
[Cl...] Posted October 15, 2021 Share Posted October 15, 2021 Please sign in to view this quote. That's actually a great idea. We did what Jayesh suggest on some similar part geometry and it worked really well. Link to comment Share on other sites More sharing options...
[Er...] Posted October 18, 2021 Share Posted October 18, 2021 This will be difficult to do depending on the depth of the cutouts. I believe if you created that planes and cylinders with all the correct size, length, geometry, etc. you can then take space points on these surfaces after they are created just as if you had a solid model. Then you can set these to a specific height, and report the greatest deviation doubled as your profile using the min/max results and a result formula. Maybe this will work for you. Link to comment Share on other sites More sharing options...
[Ma...] Posted October 19, 2021 Share Posted October 19, 2021 Just hitting vast nest but - if is any CAD software available, then max 15 minutes to create simple model with just this small area of part. Link to comment Share on other sites More sharing options...
[Er...] Posted October 19, 2021 Share Posted October 19, 2021 In Calypso 5 I have to measure the features in an Alignment that matches the DRF or the numbers are way off. Link to comment Share on other sites More sharing options...
