Filtering
Going off memory as I am not at my CMM but...
When report is open hit the F6 key. Along the top of the fly out menu click the first box (looks like a grid) which will have a drop down menu..
Click on Edit Measurement which will being up the runs of the program. From there click on <<Root Part>> of the run you want to edit. Using the icons on the top row, you can delete the results or block them all together from shoeing up on your report.
Check back if this is not what you want to do
