live view 2021
Hello,
sorry, I am not exactly sure what you mean by "old live view". Could you post a screenshot of the problem?
Regards,
Nanno
The picture in the right is the live view of the cameras in the 2021 version, the one in the left is the old. Is it possible to change the settings to have the one in the left?
Thanks in advance,
Hi,
it is currently not possible to change the view to the old view, but the wish has been accepted.
Why do you want the old view, what good does it to you?
Thank you for that! We normally work with sheet metal parts and because we don't use developer or any coat we must use manually defined areas, different exposure times or manually scanning positions and with the new live view it's harder to see those areas,
Not sure if this will help you:
If you have manual exposure settings active and click on the button for reference point exposure, the colored overlay goes away. Only a workaround, but maybe helpful.
  • 2 weeks later...
Norbert Bendl: "Not sure if this will help you:
If you have manual exposure settings active and click on the button for reference point exposure, the colored overlay goes away. Only a workaround, but maybe helpful."
=> I have the same problem. This is the solution. Thanks.👍
