Program changes from English unit to metric at random.
Have anyone ever encounter program changes from English unit to metric at random? We counter one or two times weekly. Our operator loads and run the program. At the end of the program, the output is in metric but the program is programmed to English unit. So far metric programs are not affected.
Contura G2
Vast XT gold
Calypso 2017
Version 6.4.08
Service Pack 3
Under Resources, Feature Settings Editor, Units, Length Unit, set that to Inch. If it is set to default it will change to what ever the user has set under Extras, Settings, Environment, Language. If you change users and the users don't have the same settings things will change unless you take it off default under resources. It may also be set to default under under Resources, Characteristics Settings Editor, Units, Length Unit, set that to Inch If that's not the issue then I am not sure.
it helps to have an Inch and metric template that you load and rename instead of clicking the create new button. This helps you not to forget to change it for each program from Jasons comment.
  • 3 years later...
Hello all, I was recently tormented by two questions; the first is whether someone has been faced with the arbitrary measurement program from English to metric units, and the second is that I needed a site for the proper design of proposals and that this site corrected and built sentences correctly in English.
