[Ke...] Posted October 13, 2021 Share Posted October 13, 2021 I'm measuring a part that is similar to this sketch... where the Base Alignment is set to AIBIC ; A is spatial, X zero & Z zero; B is Y zero, and C controls rotation. The feature being evaluated for position is small, and difficult to access, so I am using 4 symmetry points, along the feature. For the Position callout: Using the A datum only (whether in 1 box or all 3), the position is (e.g. 0.350mm); whch is similar to evaluationg it to the Base Alignment (A & C are 3D lines in the Base Alignment, while A is measured as a cylinder for evaluation purposes) As reference the parallelism between the feature and Datum A is 0.0143 However, If I use a secondary alignment, and use A for Spatial & XZ origins, and control the rotation with an Average Feature, derived from the 4 symmetry points... my result is 0.0298 (very close to 2 x the parallelism result. Is the CMM adapting the rotation from the Base Alignment, instead of allowing A to rotate freely? If so, using the average feature to clock the rotation and acceptable modification? FYI: I have Curve, but not Freeform (at this time...) Link to comment Share on other sites More sharing options...
[SH...] Posted October 13, 2021 Share Posted October 13, 2021 If I have not mistaken, designer is looking for symmetry of your feature wrt the datum A. I think no need of clocking. Link to comment Share on other sites More sharing options...
[Ro...] Posted October 13, 2021 Share Posted October 13, 2021 Hi Keith, Are you best fitting the DOF not constrained by datum A in the position? If A is a cylinder it should be rotation around A and translation along it's axis. Link to comment Share on other sites More sharing options...
[Ke...] Posted October 13, 2021 Author Share Posted October 13, 2021 Please sign in to view this quote. Thaaat's the ticket... Thank you sir Link to comment Share on other sites More sharing options...
