Controlling digits through script commands
Hello everyone,
Is there a way to control number of digits of dimensions ,angles or deviations through scripting? I have a mini script program which automates the measuring of a specific part geometry.However, number of decimals changes when script works on different measuring computers. Therefore, it causes different reporting format with changing decimals. Is it possible to set default decimal values with using script commands?
Many Thanks,
Canset
We asked for getting and setting the decimals within scripting in 2013, but this is actually not possible as far as I know. (RT-200-015780)
This sadly isnt possible , the digits effectively are stored in the project template -i.e use the same template on multiple machines and you should get the same output.
Be aware that digits can change based on restoring report pages that have different settings .
