Arc motion
Arc motion on what? Cylinders? Calypso has always had an arc motion on cylinders in certain situations. I think I've seen it mostly when doing external cylinders and approach from a clearance plane perpendicular to the axis. Like I said, it seems to happen only in certain situations.
I have two programs (One is supposed to be an exact copy of the other one).
The copied version (saved in 2020) behaves differently than the original saved
as 2019.
2019 travels in a straight line (Y) from one circle path to the next. The 2020
moves out in X first then along Y to the next path.
Both programs have identical
Clearance Group/Distance/Retract and both have Arc motion mode turned off.
