Eliminate ref Sphere stem from probe cal
Is there a way to eliminate the stem/shaft of the ref sphere out of the tensor qualification? I want 180 degree coverage but will crash on ref sphere stem. I was able to do this prior by making degree angle inputs (start ang /360-ang)
Anything available like this? I don't want to reduce sphere coverage.
Thanks!
Tensor will allways cover full 180° of cal. sphere.
You can mount cal. sphere to another shape to satisfy your needs.
I don't have any of unusual probes, but only one is rotated 45° with knee setted to 45° to handle one corner of a part.
I had to tell Calypso vectors of it's shaft. Otherwise i could only reduce coverage angle.
Entering the correct shaft vector when measuring the sphere should eliminate the shaft automatically. If not, check the shaft radius in the sphere management.
