[Ma...] Posted July 25, 2022 Share Posted July 25, 2022 Hello, I have to merge pdfs in a script. I've tried to install pypdf2, pypdf4 and other packages with the script "Install Python Package", but it returns errors and the package doesn't install. I've tried to install both from network and from directory downloading the package from internet, but it doesn't work. How can I do, and what package can I use for working with pdfs? Thank you very much! Link to comment https://qualityforum.zeiss.com/topic/1199-working-with-pdf-in-python-merge-and-split/ Share on other sites More sharing options...
[Fr...] Posted July 26, 2022 Share Posted July 26, 2022 Which error do you get ? In principal, it should be possible to install these wheels. The standard python pip tool is used for that purpose. Link to comment https://qualityforum.zeiss.com/topic/1199-working-with-pdf-in-python-merge-and-split/#findComment-3907 Share on other sites More sharing options...
[Ma...] Posted July 27, 2022 Author Share Posted July 27, 2022 You can tell me which is the correct procedure to install a package inside the GOM Inspect Pro? Thank you very much Link to comment https://qualityforum.zeiss.com/topic/1199-working-with-pdf-in-python-merge-and-split/#findComment-3937 Share on other sites More sharing options...
[Ma...] Posted May 6, 2024 Share Posted May 6, 2024 For SW version 2022: see Environments for python scripts — Add-On Documentation (zeissiqs.github.io) For SW version 2023: see Using the Add-on Editor — Add-On Documentation (zeissiqs.github.io) Link to comment https://qualityforum.zeiss.com/topic/1199-working-with-pdf-in-python-merge-and-split/#findComment-11407 Share on other sites More sharing options...
