User Definable Field
To my knowledge the option to use a defined drop-down box for a user defined field is not an option correct? I posted this up in "My Voice" with the link below in case it hasn't.
I'm also interested in your thoughts on the matter, It seems to me that this would help in having consistent information on measurement plans used for multiple part numbers.
https://portal.zeiss.com/my-voice/softw ... 9bcd9c5a66
Thanks for reading!
https://qualityforum.zeiss.com/topic/11992-user-definable-field/
Calypso has always been able to do this. The screenshot I posted is a result of PiWeb being incorporated into Calypso but userfield.ini was how it was done before. Actually, you can still edit the userfield.ini file to do the same thing. The editor interface is connected to the .ini file. In other words, editing in one location changes the other location.
C:\Users\Public\Documents\Zeiss\CALYPSO\protocol\protform
If you work from the .ini file, rename it from zzz_userfield.ini to userfield.ini. If you work from the editor interface, it will create the userfield.ini file. Zeiss would like us to use the editor interface.....
https://qualityforum.zeiss.com/topic/11992-user-definable-field/#findComment-59738
