Warning after power failure
My bet is on some damaged (config?) file.
Update:
The string 'userDic' seems to appear only in 'inspection' and 'inspset' files, followed by protocol header variables.
Very wild guess: If the warning pops up without any measurement plan opened, maybe Calypso goes through the last opened plans and tries to read that data section, failing at one damaged inspection/inspset file?
I would try and check the last used measurement plans on the start page for integrity. Worth a try at least.
A new config would be the first thing to try. This message is nothing but an annoyance. If a new config doesnt do the trick, then i would suggest uninstall/reinstall Calypso and the service pack.
