[Su...] Posted September 17, 2021 Share Posted September 17, 2021 Can someone explain what this means? Had a power failure and this warning pops up with no information visible. Click OK and it will close. Thank You! Link to comment Share on other sites More sharing options...
[No...] Posted September 20, 2021 Share Posted September 20, 2021 My bet is on some damaged (config?) file. Update: The string 'userDic' seems to appear only in 'inspection' and 'inspset' files, followed by protocol header variables. Very wild guess: If the warning pops up without any measurement plan opened, maybe Calypso goes through the last opened plans and tries to read that data section, failing at one damaged inspection/inspset file? I would try and check the last used measurement plans on the start page for integrity. Worth a try at least. Link to comment Share on other sites More sharing options...
[Br...] Posted September 20, 2021 Share Posted September 20, 2021 A new config would be the first thing to try. This message is nothing but an annoyance. If a new config doesnt do the trick, then i would suggest uninstall/reinstall Calypso and the service pack. Link to comment Share on other sites More sharing options...
[Su...] Posted September 22, 2021 Author Share Posted September 22, 2021 Thanks for the replies! After a few reboots and opening, running, saving the last program, the warning has not returned. Link to comment Share on other sites More sharing options...
