[Iv...] Posted November 18, 2020 Share Posted November 18, 2020 +++Repost from old forum+++ Hi there, In ARAMIS, I noticed that the current formula of determining the Equivalent Mises Strain is: PhiM=sqrt(2/3*(Phi1^2+Phi2^2+Phi3^2)) I would like to use a different formula: PhiM_i=PhiM_i-1+sqrt(2/3*(dPhi1_i/dt^2+dPhi2_i/dt^2+dPhi3_i/dt^2)) Can anyone help me program the script? Thank you ahead! Link to comment https://qualityforum.zeiss.com/topic/12-equivalent-mises-strain/ Share on other sites More sharing options...
[Iv...] Posted November 18, 2020 Author Share Posted November 18, 2020 Your request should be possible using a custom user-defined inspection. Here is a small tutorial on the topic that I made a little while back as an intro to the topic: https://tinyurl.com/rgrtekh. You can also find more information about this feature in the Knowledge Base: https://support.gom.com/display/DOCS/Customizable+Checks Reaching out to your local distributor might also prove quite helpful too! Charles Trilion, USA Link to comment https://qualityforum.zeiss.com/topic/12-equivalent-mises-strain/#findComment-36 Share on other sites More sharing options...
