Clearance plane error message
Make sure the numbers in your negatives are negative and the ones in your positives are positive. I have had this happen as well.
The numbers that should have been negative were actually positive. Just change the sign and it should work.
In many cases, you would have a plus value in one field and a negative value in the other, but depending on where the BA origin is, you could have a situation where you positive or negative values in both sides. However, you definitely want the +value to be more positive than the -value.
