[Ca...] Posted September 14, 2021 Share Posted September 14, 2021 Hello guys, did somebody of you has an idea how its possible to change that Calypso is accepting a "dot" instead of "comma" if you press the key on the "Numblock". Since a few days i have this problem, before it was never an issue. All my language settings are set to English and i even tried with "Alexs Punkt" which is a ffreeware application which exchange the "," with the "." Its working on every other application, except on Calypso. The Seperator on the dimensions is "point / dot / ." but if i press the number with the numblock its always "comma / ," If somebody has an idea, i would be very thankful. 🙂 Thank you. Link to comment Share on other sites More sharing options...
[Ma...] Posted September 14, 2021 Share Posted September 14, 2021 What about changing system settings? https://answers.microsoft.com/en-us/mso ... a8afa5025a Link to comment Share on other sites More sharing options...
[Ca...] Posted September 15, 2021 Author Share Posted September 15, 2021 Hello, Thank you very much for this hint, but i did already and it doesnt work in this case. In every application Excel, Notepad, Word etc. its working, but not in Calypso. Thank you, Regards, Link to comment Share on other sites More sharing options...
[Ca...] Posted September 15, 2021 Author Share Posted September 15, 2021 Solved this in Windows 10 with Microsoft Keyboard Layout Creator 1.4 https://www.microsoft.com/en-us/downloa ... ?id=102134 It requires .Net Framework 2.0, but I have latest 4.8. Open Microsoft Keyboard Layout Creator. I got some errors, but just pressed "Ignore" all time. File > Load existing Keyboard (find your current) Change comma to dot here: enter image description here 3b. Adjust fields in Project > Properties Press Project > Validate Layout and fix issues. In Russian case I deleted Alt+Ctrl+8 currency symbol (I didn`t even know it exists in default). Press Project > Build DLL and Setup package. Run setup.exe from build folder. Press magnifier icon and type language > go to "Language and Keyboard Settings". Select bottom "language package available" version and press arrow up till it will be upper than yours previous layout. After that delete your previous language. In my case language bar in tray dissapeared after previous step, so I used this https://winaero.com/blog/enable-languag ... indows-10/ Reboot your PC. Link to comment Share on other sites More sharing options...
