Repeat program
Hi all,
It's probably dead easy but because I have never need to use it...
How do I repeat the whole program ? Let say run a program for 5 times to see the difference in results.
I can be done in autorun - just use loops
You set up there from which pallete position to which with step - so if you want only one position, then just enter "1" to all three and repeat this entry as many repetitions you want
