On a Slot feature, why can't I select Evaluation methods other than Least Square?
On a rounded slot, I need to ensure it'll fit over a pin of a certain size on the narrow dimension. As such, the drawing has an envelope modifier on it meaning I need to select the Evaluation Method of Outer Tangental. Unlike other features, the only evaluation method available is Least Square, which would not give me the correct reading. Am I missing something, or does Calypso only let you do LSQ for special geometry evaluations?
