Renaming measurement plans.
Is there a faster way to change the plan name besides opening each program, then save-as with the new name?
We have to do a mass part number update...
Are they stored on a network? I can rename mine by highlighting the program and right clicking it then choose the rename button, call it whatever I want and then just move on to the next one.
Exactly. You can open and rename various files for each program to accomplish it, but it seems it would be easier to run some sort of batch file that opens and saves your plans to the new naming convention. I guess that would depend on what you want to rename them to and if there was a pattern/rule that a batch file would work on
Thanks all,
I figured there would be no simple solution... it would be nice if Calypso at least had a "save all" option to save all the open plans.
It does. If you have several programs open and you go to File > Exit, you will prompted with the option to Save one by one or to Save All.
The fastest way may be to rename the inspection folder then edit the corresponding "username" folder. This could probably be programmed in a script or batch file if the same change is required for a number of measurement plans.
