2020 Software no longer lets me Create 3d Lines in two cylinders/Circles
I get error pop ups.
Is this normal now with the new Software. Just wondering if anyone is having issues with 3d LINES now. Recalling Feature Points specifically.
Hello, the same thing is happening on my Calypso 2020. I just Recall whatever i need and delete the Error and close the 3d-Line Window. When I open the window again, everything is selected and calculated.
Worked for me so far. 😃
Hello - Make sure you have the latest service pack installed. This was an issue with the early release, but once the service pack is on the machine there should be no errors when using recall for a 3D Line.
I also have the same issue, so yesterday I installed the SP 7.0.12, 3d axis recall issue has been fixed.
But another serious issue happened.
When I close one opened plan OR switch plans, ERROR pops up and my Calypso stops. I have to restart it.
And the latest patch 7.2.1202 doesn't work for this. 1186_f2c326a30b0383ee8bcede278518f563.png
Now I have to install 7.0.02 again 😭
When I connected to Silvio's machine via Zoom, I found the default measurement strategy was set to use 2 circles but they were both set to 10% for the measuring height. Once we changed the cylinder strategies to measure high and low, he had no issue with the 3D Line.
