[Si...] Posted August 13, 2021 Share Posted August 13, 2021 I get error pop ups. Is this normal now with the new Software. Just wondering if anyone is having issues with 3d LINES now. Recalling Feature Points specifically. Link to comment Share on other sites More sharing options...
[To...] Posted August 13, 2021 Share Posted August 13, 2021 Try using Recall instead of Recall Feature Points Link to comment Share on other sites More sharing options...
[Ya...] Posted August 17, 2021 Share Posted August 17, 2021 Hello, the same thing is happening on my Calypso 2020. I just Recall whatever i need and delete the Error and close the 3d-Line Window. When I open the window again, everything is selected and calculated. Worked for me so far. 😃 Link to comment Share on other sites More sharing options...
[Ca...] Posted August 17, 2021 Share Posted August 17, 2021 Hello - Make sure you have the latest service pack installed. This was an issue with the early release, but once the service pack is on the machine there should be no errors when using recall for a 3D Line. Link to comment Share on other sites More sharing options...
[Ch...] Posted August 17, 2021 Share Posted August 17, 2021 Congrats on new title Caitlin Link to comment Share on other sites More sharing options...
[Br...] Posted August 17, 2021 Share Posted August 17, 2021 Caitlin is right.. With the latest service pack, this will not be an issue Link to comment Share on other sites More sharing options...
[Jo...] Posted August 18, 2021 Share Posted August 18, 2021 I also have the same issue, so yesterday I installed the SP 7.0.12, 3d axis recall issue has been fixed. But another serious issue happened. When I close one opened plan OR switch plans, ERROR pops up and my Calypso stops. I have to restart it. And the latest patch 7.2.1202 doesn't work for this. Now I have to install 7.0.02 again 😭 Link to comment Share on other sites More sharing options...
[Da...] Posted August 18, 2021 Share Posted August 18, 2021 Please sign in to view this quote. What if you try patch 7.0.1201? Just guessing. I can provide a link to it on afternoon. Link to comment Share on other sites More sharing options...
[Da...] Posted August 18, 2021 Share Posted August 18, 2021 There you go -> https://we.tl/t-NnqZhSAytj Link to comment Share on other sites More sharing options...
[To...] Posted August 18, 2021 Share Posted August 18, 2021 When I connected to Silvio's machine via Zoom, I found the default measurement strategy was set to use 2 circles but they were both set to 10% for the measuring height. Once we changed the cylinder strategies to measure high and low, he had no issue with the 3D Line. Link to comment Share on other sites More sharing options...
