Accessing different Databases
Good Morning,
I have been using the piweb table template to filter and only show dimensions out of spec to make it easier to see which parts are bad and compare them to each other.
It becomes an issue when I run one order on multiple CMMs. I have to go to each cmm and grab those reports from them. It becomes a bigger issue when i go into my offline seat and try to access the data from it but it is unable to find any data.
Is there any way to link or pull data from each CMM's database that's stored in the C drive?
I tried opening inspection plans that are stored on the network but it will still only show data that was ran on that CMM im accessing the data from.
Thank You,
Can you put s folder out on your network and tell calypso to save the results to that folder? That way all the pdfs are in one location on your network.
If they are all standalone machines I'm not sure of a way you can do what you want since its multiple results.
Others may chime in with another soultion(s)
In CALYPSO there is PiWeb reporting and PiWeb reporting plus (CALYPSO option ==> PiWeb reporting plus).
These are the single-user versions, each with its own database. If you want to evaluate data together, you need a PiWeb server solution (PiWeb sbs or PiWeb cloud, or PiWeb enterprise). The TableProtocol.ptx was developed for the CALYPSO single-user solution. But can also be used for the PiWeb server solution. (For the PiWeb server solution, then it makes sense to remove the root data binding)
Tip:
The new TrendProtocol.ptx or the Dashboard.ptx are also suitable for data compression. If you have more than 10 data records or you need statistics, the CALYPSO reporting plus option is required. The Dashboard can only be started from the reporting plus interface
