Shaf seal control
Hello dear friends!!!
How are you doing?
I need a opinion about Shaft seal measurement.
Is it correct the measuremet wiht Cylinder styli?
I understand that can larger diameter because contact is bigger.
The measuring force is already lower.
See you.
Cheers!
Haya Clarke Gilbert!
Tks for feedback.
This worpiece is (rubber coated metal).
Look the figure (probe simulation int the point maximum). About measurement, just doubt about the best method.
See you!
Cheers!
It depends on the accuracy you need. Cylinder probes aren't as accurate because Calypso doesn't know where the probe is actually making contact, so it can't compensate as accurately as a sphere probe.
Do you have the Curve addon? I would scan the "wave" as a curve and extract the highest point. Or if you don't have Curve you may be able to use a 2D line feature the same way.
