moving speed of feature not as programmed
Hello all,
Why is my program only following the speed inscribed in the RUN window and not teach individual speeds I have entered in the program. I programmed some features to be slower but they are fast as the value un RUN window.
Thank you, I really appreciate all the help I can get on this forum.
The speed in the Run window only affects travel between features. Scanning speeds are controlled within the strategy. If you need to control the travel speed within a specific feature, you can adjust in the Features Setting Editor. This does not change scanning speed.
I edit the displacement speed of each feature in the "measurement plan editor features". I guess it is the editor you are talking about but the run is still not following these slower speeds. I am not trying to change the scanning speed, I know it's controlled elsewhere.
Anything else please ?
Make sure the power control key switch is turned to auto or the CMM will only run 50% or slower no matter what travel speed you put in higher in Calypso. 164_3257428a4964fbc7957d669e111c4007.jpg
