[Ja...] Posted August 10, 2021 Share Posted August 10, 2021 Hi all, I am fairly new to using pi web reporting. I have updated calypso and pi web reporting. The new version of pi web is not showing databases from the older one. I have done parallel install, imported all the data while setting up new calypso version. How do I make old version pi web reporting databases appear in the new one. The file path is set to new version, I have copied dfm files from old version directory to new one but it still wont load. Link to comment https://qualityforum.zeiss.com/topic/12290-new-to-pi-web-reporting/ Share on other sites More sharing options...
[de...] Posted August 10, 2021 Share Posted August 10, 2021 Which version of Calypso are you using? New Calypso uses DFS instead of DFM. You can convert them using the ConvertPiWebDatabases utility, and write them to the location that PiWeb Reporting is looking in. Link to comment https://qualityforum.zeiss.com/topic/12290-new-to-pi-web-reporting/#findComment-61482 Share on other sites More sharing options...
[Ja...] Posted August 10, 2021 Author Share Posted August 10, 2021 Yes, zeiss tech told me the same thing and that solved my problem. Thank you. Link to comment https://qualityforum.zeiss.com/topic/12290-new-to-pi-web-reporting/#findComment-61484 Share on other sites More sharing options...
