Combination of Restrictions??
Has anyone seen this before?
I am measure a plate with a profile call out of .002 on two radius's.
I am scanning a cylinder and characterizing it with a profile characteristic.
This plate has two other radius's with the same radius size in a different location using the same strategy and they're coming out good.
Regards,
Are you constraining any axis or size of the radius/cylinder?
It seems like I've seen this when constraining and because either the location or size fit is exceeded or maybe you don't have enough point density for the filer afterward ?
Thanks for the response Owen,
That was my first thought was the filter and outliers so I removed those and still getting these results.
I don't recall being able to apply constraints to a profile characteristic.
Point density. The first time I ran the part I had 702 points and I bumped it up to 1500 with the same results.
Regards,
