Temperature compensation
Hi there,
I would like to ask if it is possible to recall old measurement and define different temperature.
If for example operator forget to activate the temperature compensation before measuring.
Thanks!
I load last measurement and re-evaluate it with different temperature given for compensation.
The results were the same as they were for the first time.
The temperature compensation is not something that can be changed after the fact.
The way that it works is that it reads the temperature, creates the offset, and takes the measurements with the offsets already applied.
If you wanted to "simulate" the data with a different offset, you could do this in excel with the raw data, the temperature delta, and the coefficient.
