Calypso - Excel Report in a predefined folder
Hello,
Is it possible to save a measurement report in excel format in a predefined measurement folder (diffrent for each CMM programm)?
It can be done easily for pdf reports in the multi protocol function, but unfortunately I don't see it for excel.
Under Resources, name for output files, Calypso can be set up to export most files to a specific location, except actual Excel files. The work-around that is often used is to turn on Table files and edit the output Characteristics table file with an xls file extension. Excel will open this file but it is not an Excel workbook. Excel opens it as a text file. Then, you can do a "Save As", and select Excel workbook as the file type.
