[Ro...] Posted July 16, 2021 Share Posted July 16, 2021 I'm new to Piweb. Loaded up the StandardProtocol.ptx template. I'm not getting any form plots. The document I have says I can choose "detailed mode", which I'm not seeing. The documentation for Piweb is less than desirable. Also, any tutorials or documents you can point me to on using Piweb would be great. Thanks, Robert Link to comment https://qualityforum.zeiss.com/topic/12364-display-form-plots/ Share on other sites More sharing options...
[To...] Posted July 22, 2021 Share Posted July 22, 2021 Please sign in to view this quote. I am working from memory so I don't remember the names correctly, but at the bottom of the multiple report window, there are 3 check boxes. Check the 2nd box to initiate the detailed portion of the report. Then, check the 3rd box to allow access to options to turn plots on or off. This list is also found in the characteristics setting editor under the plot section. Link to comment https://qualityforum.zeiss.com/topic/12364-display-form-plots/#findComment-61816 Share on other sites More sharing options...
[ef...] Posted July 22, 2021 Share Posted July 22, 2021 If you'd like to view the form plots on an as-needed basis, ie. when something is out of tolerance, you can click the small form plot button in the top ribbon of the report page, next to the filter icon. Select 'Detailed' from the pop-up dialog. It will exchange the protocol row templates for the form plot view. You can click on these smaller plots to open a large, full page form plot. Link to comment https://qualityforum.zeiss.com/topic/12364-display-form-plots/#findComment-61818 Share on other sites More sharing options...
[An...] Posted July 30, 2021 Share Posted July 30, 2021 Here are a few KB articles in regards to displaying plots in PiWeb. Hopefully these can be of use. https://portal.zeiss.com/knowledge-base ... &id=523075 https://portal.zeiss.com/knowledge-base ... &id=409277 Link to comment https://qualityforum.zeiss.com/topic/12364-display-form-plots/#findComment-61820 Share on other sites More sharing options...
