Vector Direction Invert
Hi guys,
I have a problem, I was make a new program, and I don't have CAD model, Is a metal plate with 250 points on the surface but when I make the program the vector point was inverted, attach photo.
Is posible change position vector of point?
Thanks for you support.
Are you using 2d curves?
If so, open the curve and under the Nominal point information drop down, choose "Change Nominal Vectors"
Yes, it can be done.
I've always had the curve option and it makes it easy to convert vectors.
However,with a bunch of individual space points, I think you'd have to change the IJK vectors of each individual point to do it. To avoid having to open each feature one by one, I think you could use the measurement plan editor list option to change them all on one page.
Somebody may have a better way?
I don't have curve, but I was change the IJK vectors 🫣 and ready.
Thanks for your attention.
  • 2 years later...
Hello Guys,
I have the same problem with 1121 points. Is there a way to reverse them all at once ? Is too hard to modify I J K one by one of 1121 points.
Thanks.
The original post looks like the view is simply upside down but that is a few years old. You can change the i j k numbers under resources, Feature settings editor, geometry (nominal data). You can highlight and change them all at the same time.
